Galaxy RIO outputs
Okay, I think I have worked out your issue. You have the slave jumper open. This needs to be closed, then power cycle the RIO to pick up the jumper change.
FFS, that worked, the outputs work as they should do now, I seriously can't thank you enough for all the help you've given
Thank You, Josh
No problem Josh. You'll find the Galaxy is a very reliable panel. Just replace the battery every few years and you should be fine.
The battery is automatically load tested every night, so the panel soon lets you know if there's an issue with it anyway.
