Hello all, this project wasn't dead, just sleeping...
I've been doing some background reading and planning before putting my money where my mouth is. Need to know if this is looking right and also need advice on a few points along the way. Thanks!
FLOOR
Grind down any high bumps on concrete floor
Thoroughly clean and dry concrete
Paint on a vapour seal/DPM
(need advice what to use. Garage is 2.5x5.5m)
Self leveling screed floor
(need advice again)
Lay lino - either self adhesive tiles or stuck down with spray adhesive
CEILING
Add ventilation through facia in eaves
Attach 47x150mm ledger board around all 4 walls
2 rows of screws spaced at 300mm into rawl plugs
Joist hanger nailed into ledger board at 600mm centers with 2" nails
47x150mm C16 rated joists cut to be a tight fit and sat into joint hangers
Hammer through joist hangers with 1" nails
47x150mm blockers between joists
Hire a plasterboard panel lifter
Screw plasterboards into Joists using 45mm drywall screws
(long enough for ceilings?)
Leaving 600x600mm hole in center of room for loft space access
Insulation between joists and above joists running perpendicular
Plaster finish over plasterboard join and screwheads
EXTERNAL WALLS (trying to follow advice from
celotex website)
Breather membrane on external walls
(what is this? where to get it?)
50mm Celotex insulation boards along the external walls
(how to fix in position?)
Celotex Insulation tape to join insulation board and complete vapour barrier
Mastic to seal around insulation
(top, bottom, left and right??)
25x50 timber battens top and bottom
25x50 timber battens at 600mm centers
25x50 timber blockers between battens
Plasterboard pushed flush with ceiling
(probably slightly off floor?) screwed in place with 45mm drywall screws
(easier if plasterboard is square edge or tapered edge?)
JOINING WALL
Already insulated between garage and house
Plasterboard dot and dabbed directly onto brick wall
