Hi
i've got an outside light on the wall which is switched from indoors, i would like to remove the light to fit spotlights up the garden.
Im after a bit of advice as if this is the right way to go about it.
I want to remove the light and fit a IP56 junction box on the wall and run 2.5 swa cable along the side wall, this will then be buried into the ground as it runs up the garden.
The spot lights will then be connected to the cable as it runs around the garden, fitting about 5 mains spot lights, when it gets to the decking i will connect it to a transformer and connect LV deck lights.
Or would i be better fitting LV spotlights with 3 lights on one transformer and fitting a couple of transformers around the garden and the decking.
Bret
Bret
