I have just fitted a gas hob and want to know what a reasonable price would be for connecting the gas.The pipe is about 12 inch from the hob connection but at the moment there is only the socket for the cooker
£40 is fine if all that he has to do is tee into the existing pipe. What if the existing is 15mm and it's not sufficient for the cooker and hob. It may be that the existing pipe needs refitting in 22mm. Or is the fitter going to just fit it and not worry about the poor pressure on the hob?
