I would like to have a combi installed for dhw only at present. The cold and hot water pipes for dhw are in the correct location and the power is already there. There is no CH circuit and won't be for a year or so. So would require someone to hang the boiler in my loft (loft is prepared) fit the flue through my roof. and connect the condensate. I have opened up my "stink" pipe in the loft and a strap on boss is fitted.
I would also need a gas pipe from my meter run through to it but this can be done without any floorboard lifting.
Can you give me rough ideas of cost to do this? I'm not after a quote because that would be impossible without seeing my house but what is a rough guide?
I'm asking here because sometimes I'm nervous getting people in for quotes due to bad experiences in the past so if you could help out I would be very grateful.
Cheers,
Andy
Cheers,
Andy
