I have had an issue on my boiler for a while now where I don't get a full flame either when starting up (rads cold or CH not up too temp) or running the DHW.
Boiler is a Glowworm 100e
The rads do eventually get warm and you can also get hot water if you throttle the flow back.
I've searched this forum and realise I can get the gas pressure checked but out of interest - If I had a problem with the gas pressure, can that effect my gas bill ? ie could It be costing me more as my boiler is producing less heat for the volume of gas supplied because of the low pressure.
Thanks for your help.
