gate hinge fitting problem
16 Sep 2014
West Glamorgan
hi,
I have (unfortunately) bought a pair of 3ft gates made with stub tenoned joints and dowels.
my problem is that when I come to fit the band and gudgeon hinges, the BOLT hole sits over the dowel. I can move the hinge down a few mill and back a few mill (which will look a bit) to avoid the dowel, but then ill be drilling a hole and putting pressure right next to the dowel.
im not sure wether to:
-drill right through the dowel, thus making the bolt do the job of the dowel, but risk getting more moisture in to the joint.
-or to rerill the hinge to place the bolt on the horizontal bar near the screw holes, rather then were it sits now on the vertical bar, but would this put the weight on the wrong part of the gate, ie all on the horizontal bars.
-or fit without a bolt at all?
any ideas whats best please, (other than buying new gates lol)
thanks
sam
Read more: //www.diynot.com/diy/threads/fitting-gate-hinge-dowel-in-way-of-bolt.431049/#ixzz3VxtNOgQk
