- Joined
- 21 Apr 2007
- Messages
- 58
- Reaction score
- 0
- Country
Hi,im installing a basin in the downstairs toilet.It has a basin in but no hot water,just cold.how do i get hot water to it?
cheers
ben
cheers
ben
WelshMan said:i would suggest 22m if its a fair distance and then reduce it to 15mm.
Quite the reverse actually.WelshMan said:Also thought with the bigger bore he would get the HW quicker...
I don't think it's possible to be quite that certain.JohnD said:Quite the reverse actually.
Er, actually the 22mm pipe, in this scenario, would hold about 2.37 litres.Suppose the pipe is x metres long. A 15mm pipe of that length holds 1 litre of water. A 22mm pipe of that length holds 2 litres of water.
The trouble is that 22mm pipe is less restrictive than 15mm pipe, so it's possible that it could take less time, not more.The 22mm pipe will take 1 minute to flush through all the cold water it contains.
