Hi all,
We moved house in late October from a property with a MegaFlow and Combi boiler, bills were for it were good, during the winter we kept it on 24/7 using a Heatmiser digital thermostat to control the temperature.
Our new property has a Gledhill Thermal Store unit and a Pottern boiler installed when the house was built about 8 years ago. We just got our bill from November to early Feb whoa! I thought thermal stores were economical but our bill is huge and we have not been leaving it 24/7 partly as the boiler and the pump are quite loud.
I'm after some tips on how to keep the bills down.
The boiler is set to come on about 7am and go off about 8:30am and then again at around 4:30pm and off about 10:30 pm, thermostat is at 21 degrees C
With this system as I understand it though out of these times the boiler can come on to heat the water in the tank, this seems to happen quite regularly and even in the middle of the night. The water is also heated to a very very high temperature and then using a valve on the cylinder you mix it with cold water so you don't burn yourself when using the taps. But to me this does not make sense, I'm paying to heat water up to then mix it with cold water to cool it down
Also the Summer/Winter gauge on the front does not seem to affect the temperature of the water but the amount that is heated up. For example while its in the Winter red area we get enough hot water to half fill a bath but when in the Summer blue section we only get a couple of inches of hot water - is this correct??
And finally (sorry this is so long!) we get a annoying buzzing coming from the cylinder at random times every couple of days, it last for a few seconds then stops.
Any help appreciated!
