Impartial advice? . Should that not be changed to untrained advice and guess work.
I give advice based on 20 years of experience. I would go so far as to say that we are unique in the depth of knowledge we have (I include my staff,)
I do not need to have been trained as a fitter to understand most boiler problems (although if I don't know, I say so), lets face it gas fitting is hardly rocket science
Your not actually trained in gas work and hold no qualifications and have no experience in actually working on appliances do you.
I have a degree and 20 years experience, I'll say i5t again- gas fitting is hardly rocket science
When these customers have bought pcb`s on your impartial advice and your wrong do you give them a full refund inc postage.
it depends on whether I tell them I an 100% sure
Yes the check list would have found the fault but it is always better to put any check list in a correct sequence not the least likely and most expensive first ,otherwise all lists would start with ... Renew boiler.
you really are an idiot, aren't you
looking for some little reason to triup me up
Look and learn, loser, if someone buys a pcb from me, it's often the cheapest option
for example £30 for a profile pcb as opposed to getting some RGI twonk out at £50+ just to turn up
