glow worm comact 100e
17 Oct 2008
Hampshire
can anyone help; my gloworm central heating has started cutting out,it shows on the lights that the water is on ,so the heating cuts out as they cant run together ,but the water is not on..HELP ME IM FREEZING
Flow switch has leaked causing the micrswitch to short. Replace both parts including the diaphragm. Not a difficult job but you will need a torx driver or allen key- T15 iirc
hi thank you for that i changed the flow switch and diaphram about 6 weeks ago will look at it again..cheers
