greenstar 24i, hot water problem
23 Mar 2009
Blackpool
hot water not constant on my greenstar worcester bosch 24i boiler, it starts and runs but the water runs cold then hot (not constant),there is also a gurgling noise from the burner cylinder in the boiler,the water gauge is sitting at 1 bar. anyone have an idea what could be wrong?
A gurgling noise is often caused by a blocked condensate trap or drain.
That would also cause the burner to go out.
I once went to one with this fault at which the Worcester engineer said he had "never heard that before" !
Tony
Thanks for that. I checked the compensator pipe, which is running.Don't know if it should be, but the outer compartment of the syphon trap is full of water. The compartment at the back is half full of water. I have just noticed that the hot water runs constant when the c.h. is on.?
