how does guest houses and hotels run miltiple toilets when not against outside walls so theres always away to do it even if you need to run internal soil stacks i take it thats costly
All the services in hotels ect are (normally) carefully planned with ducts built into the fabric of the building to solve problems of noise, concealing of pipes ect, the stacks run in these ducts and then run underground.
its 4 saniflos i need to get rid of them even i need to get internal stack built hope someone will come up with ideas even at great expence surely theres away i think joists are in my favour so hopefully go outside even if new stack outside does joists run the same way on each floor i know the loft runs way i like
