H/W / C/H indicator panel
20 Apr 2005
Gloucestershire
Is there a way of wiring up an indicator panel to show if there is demand for C/H or H/W on my system? Just a couple of bulbs fitted in a standard blank switch cover, but I don't know how to wire this in to my system.
It's a two zone central heating system with a Mega Flo hot water tank
Standard boiler - not combi
Is this possible?
Morceau de gateau.
Your motorised valves will each have a brown wire, which goes live when the connected circuit has a call for heat.
Thanks for that, I'll check it out, but in essence, that means I will need three lights - one for H/W and then one each for the two central heating zones?
If you connect the indicators to the the orange wire then BOTH will light up together, you must connect the HW indicator to tthe BROWN wire to the HW valve and the CH indicator to the BROWN wire to the CH Valve as has alreadsy been said!! :rolleyes: ;)
