I am trying to fit a set of three mains voltage halogen spotlights in place of a ceiling rose.
Got a bit carried away taking down the old ceiling rose and didn't note the cable positions as I thought it would be much simpler than it is!
I have got three cables coming down from the ceiling which I understand is loop-in wiring.
I think I have identified the switch cable by going up into the loft and finding the cable that looks like it goes down the cavity wall where the switch is.
So I have all the red cores connected together.
The earth cables connected the earth on the connecting block.
The black core of the switch cable going to the brown on the connecting block.
And the 2 remaining blacks going to the blue on the connecting block.
Now when I turn the power back on and try the switch (a 2 way dimmer and the only switch in the room) nothing happens. When I try the landing light the halogens come on dimly, if i try another light upstairs at the same time, the halogens come on brighter.
Right - now thinking that I have got the wrong switch cable so try the other two. One does the same, the other does nothing at all.
Sorry this is so long winded, but what am I doing wrong?
