I have a Halstead Ace high boiler about 4 years old. Since I installed it, it has run fine.
Now when calling for DHW it seems to take longer for the burner to fire up.
Also when the hot water is running the burner will go out for a short while and then relight again, resulting in the shower going Hot and Cold.
If I turn down the temperature of the DHW to about half way then it will keep lit, but the water is not hot enough.
The boiler also locks out occasionally, but resets OK
Any ideas what the problem could be ???
