- Joined
- 27 Jan 2008
- Messages
- 23,733
- Reaction score
- 2,675
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have had sky for many years and over time, the signal has got slowly worse. So we decided around a year ago to get rid of it. At which point the guy from Sky persuaded my wife to keep it and they would send around a guy to correct the problem.
He replaced the dish and LNB and told us the main problem was the cable between the LNB and box. But said since it was routed through the loft he could not replace it. Odd since that was put there by Sky in first place. I got some TV cable and replaced it but seems although better it was not A1 quality and we still had problems.
What seemed odd with the FTA channels the FTA box could receive these without a problem on the cable condemned by Sky as being faulty so I considered it more likely the box was at fault.
So a couple of weeks ago again my wife phoned up to cancel Sky. This time they persuaded her to up-grade to Sky+ and the guy came and set it all up. Seemed OK at first then started to get problems again. So I had a look at what he had done.
Seems he had gone into my garage and removed two coils of cable. One he snipped off and left in a heap the other he had re-fastened to Landers and connected to the second input in new Sky+ box.
The other end of this cable went to my FTA box in bedroom as it both stopped the FTA box working properly and the signal received on Sky+ box varied according to what channel I was trying to view on bedroom box.
So I phoned up Sky.
Guy 1 arrived but said this was an installation job and not his job to correct a faulty installation and said he would arrange for original guy to return.
Guy 2 arrived and said it was two man job as working at height to fit new cable onto LNB so again did nothing and said he would get them to phone me and arrange another visit.
No phone can so I phoned them seems they got fax machine scream and left a voice message! I would have thought most people can tell difference between answer phone beep and fax machine scream?
Guys 3 & 4 arrive. Now they tell me they are height working team but because the roof has no apex to hang ladder from they can’t work on slopping roof of kitchen extension even though both the original installer and repair man of 12 months back had both worked off roof. Although slopping it is not slopping very much I have no problems walking on it. So I asked then why not fit new dish. Seems I am an existing customer and only new customers can have new dishes.
So now the original guys are supposed to come out. To it seems correct their work. But how they can work on the slopping roof and others can’t I don’t understand.
All except the guys would set up Sky+ have agreed that the both the cables from box to LNB need renewing. Yes I know I could renew them myself but I do not really want to mess around changing cables especially when I know they work OK with FTA boxes. I have had three FTA boxes on the cables all work A1 but both the PACE and the AMSTRAD Sky boxes have had problems.
I have a satellite finding box which is not too good and I have found the built in finding tone of the FTA box works better however Sky is not cheap and I don’t see why I should have to DIY a Sky installation?
Am I doing something wrong? If not running A1 by end of tomorrow I think only option is to cancel Sky completely however good it may be when working it’s just not worth the hassle!
Since no one has replied I will add this to original post. Today yet another guy arrives again he refuses to do anything to correct the problem. But he gets his foreman to call. He arrives and looks at the problem and agrees that to the letter the fitter should not work on the roof but says normally they would but once the first guy refused they would realise there would be a record of the problem so became a "Jobs Worth" situation. So he has now agreed to get a new dish fitted which will not require access to roof and new cables to box which should happen Sunday.
Should I claim a rebate from Sky for the three weeks when the new box was fitted but did not work correctly?
So I phoned up Sky.
