HEATING DOES NOT WORK UNLESS HOT WATER IS ON ALSO
19 Dec 2010
London
The issue is straight forward, the heating will not work unless the hot water is on also.
The conventional boiler heating/water system is all new within the last 12 months. The plumber that installed the system states that it is normal operation, and that you have to have the hot water on to get heating. To me this does not seem right however, especially with the current cold weather in the UK, when the heating cannot realistically be tuned off. The result is the water is continuously on which cannot be efficient!
Is this really normal operation?
The hot water however can be set independently from the heating i.e. in summer when the heating is not required, it is possible to just get hot water, which is good.
Background info.:
Boiler: Worcester Bosch Greenstar 40CDi (new)
Timer: Honeywell (new) - old fashioned but does have separate controls for heating and water.
Any pointers gratefully received! Thanks.
You are completely right.
get him back and ask him to sort it.
Maybe as simple as changing the set up of the clock or maybe some wiring changes.
Sounds like you may have a problem with the hot-water cylinder, get him back and and ask him to sort ASAP. The weather is getting colder so he should make a point of sorting it for you. Good luck!
Had the same problem at my mother's flat. Could be the control valve to the CH circuit is not switching on the pump/boiler when fully open.
Try moving the little manual lever on the valve motorhead if it has one. This maybe located by the HW cylinder. The lever is spring loaded shut but can be latched in the open position.
May need a new motorhead. (note: not usually the whole valve just the motorhead)
That is a lie.
Installer either doesn't have a clue, or tries to pull a fast one. Unless you have a very large house (20 big radiators) I'd say he is clueless.
