Advice Required as just had engineer round to fit new rad.
He has recommended that system be power flushed.Had to fit new pipe to one rad and replace another (due to blockages) and on testing system has found rad that was fitted only 2 years ago has started to leak badly centre top and possible bottom (column type with twin tubes).
He believes that this is caused by corrosion in system as system has been installed with HEP20 pipe.
He is recommending system powerflushing and magniflow fitting.
Advice appreciated as rad that has failed was not cheap as designer type .
Boiler is Halstead Ace High not sure of age as was in house when we bought.
