Heatsleave 9.24 BF hot water probs.
30 Sep 2009
Sheffield
Help needed, I know its old and may need replacing but was working perfect until water board put new pipes down the street (lot higher water pressure now had to renew all tap washers for drips aswell). Since then the hot water doesnt work but central heating is fine. | suspect the flow switch but cant find proper info on it. CG 47 311 02 is no of boiler but worcester website downloads dont look like inside of mine? Any help/advice appreciated. Is there any checks I can do before picking phone up? :(
Forgot to mention I can still get some hot water by putting the heating on to start the boiler, does this indicate the diverter valve assy stck in one position?
Diverter valve diaphragm & spring etc could be worn.
Kits only £4.50 here
Easy to change.
