Help, Alpha HE CB33 Combi Boiler wont pressurise
14 Jul 2011
Nottingham
Hi there
Does anyone have any advice? My boiler seems to have lost pressure (is under the 1 bar green line) and I have no heating or hot water. I've tried turning the valve tap underneath to let more water in and repressurise it and it turns but i cant hear any water going into the boiler...
I can only see one valve tap underneath, should there be another one?
some filling loops have 2 valves some have only 1 can you post a pic of your arrangement ?also what are the neon lights on the front of the boiler showing? it might not be low system pressure that is preventing the boiler from working
Thanks Ian - I will post a pic of the arrangement when i get home shortly... The lights are flashing red and green alternately....
Cant be red and green can only be red and yellow yes this would indicate low system pressure.
6.5 INDICATOR NEONS
When neon A (red) and neon B (yellow) are illuminated, the following conditions apply:-
Neon
B Flashing very slowly (every 5 seconds) - Electricity supply to the boiler is on.
B Illuminated continuously - Indicates the burner is alight.
B Flashing on and off - Temperature sensor fault.
A Flashing on and off - Overheat or flue thermostat has operated. Rotate selector switch to the reset position (3) to reset.
A Illuminated continuously - Burner has failed to light. Rotate the selector switch to the reset position (3) and the
ignition sequence will restart after a delay of about 30 seconds.
A and B Flashing on and off at the same time - Blocked flue or fan fault.
A and B Flashing on and off alternatively - System pressure is very low and re-pressurisation is required.
A Illuminated continuously and B flashing - Pump fault or restricted flow.
Ahhh, must be colourblind!!
I would say its this one:
I'll post the picture of the underneath shortly
All sorted now, there was another tap thing, just didnt have a cover on it so i couldnt see it.
Thanks for your help! :)
No problem glad to be of assistance it is what this forum is supposed to be for
