Hi, I was looking for some advise please.
I am looking to build my own shed rather than buy an off the shelf one.
I will be putting down a concrete base to place it on and raising this off the ground about 6 inches ( i think this will be hight enought to stop water getting in fronm the ground, correct me if i'm wrong)
When biulding the frame for the shet should i build it about an inch bigger than the base ? also what would you recomend for the outside wall material, you will not be able to see it when its finishe on the front wall, so what is a the cheapest zero / low maintanance option for the 3 hidden walls ??
Looking to build this about 18 x 12 ft..
