- Joined
- 10 Oct 2007
- Messages
- 3
- Reaction score
- 0
- Country
New to forum, I'm going to replace my boiler it is an Ideal Excel, pretty old brown coloured thing which apparently there are no longer service parts for as I treid to get it covered my British Gas warranty scheme.
have a small two bed house, 6 rads at moment but want to add one in kitchen, I have had a 3 plumers round to get quotes but been getting conflicting info.
wanted to swap to a combi for efficiency, been told I have a 15mm gas inlet pipe and this needs to be changed by law to a larger 22mm ? pipe, another said he can fit an Ideal Isar bolier which operated differently to others and can safely work on 15mm as not pressure sensitive. Can run a bigger pipe but going to invlove alot of work to do so would like to avoid if possible.
Also have refurbed cast iron rads which one has told me will ruin new boiler with rust deposits they have inside.
Must say apart from boiler being a bit noisy never had a problem in three years of living here, did how ever drain the syatem once myself and refill but did not realise about rust inhibiter so been running for last 2 years without it.
Any help please as they way to go.
Thanks,
Andrew
Surrey
Thanks,
Andrew
Surrey
