Hi all members of DIYnot.com.
I have a question on a lighting circuit and radial/ring etc and could really use some help with it if you could be so kind?
I have designed a circuit feeding 5 ceiling roses splitting the circuit down to 5 lighting circuits, 2 of which is one way circuits, one is two way with intermediate switching and 2 is two way switching. All this I put on one CB but now with doing a cable calc it seems to not comply. I have now changed the design to feeding the ceiling roses separately but some of the circuits are still too long to comply with the volt drop etc. I am measuring the length of cable from the CCU to the rose, down to the switch, across the strappers and back up to the light furthest away from the switch.
If the volt drop is too great to comply can I run in a 2.5 T&E for the lighting circuit? Any advice on this will be great as I can’t find anything in the BS7671 to say I can’t do this but I have never heard of a circuit for lighting using any thing bigger than 1.5mm etc.
Also if u had 3 rooms and a hallway but the total floor area was over 100m (squared) would you run in 3, A2 radials etc to each room as 100m(squared) seems really small for a house/circuit etc. even my house is bigger than 10m x 10m but still got 1 upstairs ring and 1 down stairs ring?
Thanks for any reply in advance as I am struggling with the planning of this project and really appreciate any help given, I want to get good marks etc (college project).
Thanks again.
T.
Thanks again.
T.
