Yes I guess your correct on the circuit only being one circuit as it comes from one circuit breaker, although it not just feeding one little circuit (I believe).
You should be able to fit downstairs lighting on one circuit - 1.5mm cable will give you 59m.
I was going to go to one room(dinning room)/rose, feeding the two way and intermediate switches that controls the dinning room lighting:-
Is there a specific reason that you are using intermediates? Is it just to show that you know what they are - know how to wire them and how to use them. Or is it because there is a practical reason for using them?
two wall lamps rated at a 100W each and ten GU10 recess lamps rated at 50W each spot.
Think about what you are saying here - you are putting 700watts in single room?
You will fail this project if you do not take account of the Building Regulations. You will also need to take into account illumination laws that you should have been taught (inverse square laws).
From the feed/rose that comes down to the switch, I was going to spur from that and split the supply to go to the lounge where from another junction box/rose has been installed, there I was going to run down to the two way switching and up to lights etc, two 100W pendants and two 100W wall lights.
You are over complicating the issue.
Once again then splitting the supply to different roses controlling the hall lights:- two way switching with six GU10 recess lamps.
Outside front lights:- one way switching, two 100W coach lamps.
Out side back lights:- one way switching, two 100W coach lamps controlled by a PIR setting.
You do know that they don't make 100w incandescent lamps anymore (since September 2009)
I am sure even though it on one CB that the hall lighting would be on a seperate circuit than the lounge/dinning room lighting etc. The only reason I am splitting the feed is to just get the power directly to the switches? Please tell me if you know something different?
You are over complicating this project and in doing so are breaching various elements of the building regulations. To be honest you are better off designing a circuit that has one central ceiling rose in each room first. Then add a couple of wall lights in one room - the two way switches for the hallway and landing and leave it at that.
