I need to install a shower pump in our airing cupboard (not in the bathroom) and was wondering if I could put an FCU on the circuit before the wiring for the diverter valve, central heating pump and hot water tank thermostat. However I can't figure out what's going on with the wiring.
The wiring for div valve, CH pump and HW tank are connected to a chocolate block behind a plate on the wall which obviously goes off to the CH timer. Above that there is a switch which you would assume isolates the supply to the above. In that switch there is one twin & earth cable but the wiring seems to go back down to the CH timer with the other wiring and doesn't actually seem to isolate anything in the airing cupboard.
What is the purpose of that switch and is it possible to run my shower pump off of it?
My house was built mid-80's if that is of any relevance.
Any help much appreciated.
