Hi all,
Im a bit stuck with trying to get a door contact to work on an EOL config on a Pyronix/Castle Euro Mini Panel.
I have programmed the panel to use 4k7 for alarm and 2k2 for tamper...seems to work fine with the PIR's i've tested (although they have the pre-wired jumpers in them)
If it's displaying (www.pasteboard.co/wEgPO0fcj.jpg), the above photo is how i've wired it. I've taken everything else off the panel. Apart from Z1 (set to intruder for testing) all other zones are set as unused.
So, I have put a 4k7 alarm resister over the two silver contacts. The other silver contact goes to COM in the panel
Theres a 2k7 resister on a single silver contact (shared with the 4k7) with the other side going to Z1 in the panel via the brass screw
Panel comes up with no faults and arms properly. When I remove the reed switch from the magnet it does not set the alarm off or activate the entry timer...it just stays set.
The reed switch is working fine as I tested continuity.
Have I done something stupid? I've tried new resistors and wired it up several times!
Please help
Please help
