Henry HVR200-22 Hi-Lo Speed Problem
6 Dec 2021
I have a Henry HVR200-22 that has a problem with the hi-lo speed functionality... I know these are notorious for developing faults, but my situation seems a little bit more unique and I can't find any similar cases online.
My Henry works absolutely fine in "Hi" mode, no problems vacuuming for prolonged periods. However as soon as I switch to "Low" mode the motor immediately steps down to lower suction (great!) but then carries on slowly winding down over the next 60 seconds or so, to the point where it just grinds to a halt and stops dead. Switching it back to "Hi" mode immediately fires it back up again, but I'm keen on reviving use of the "Lo" power function.
I took Henry's head apart and found the 2-speed PCB... it's one of the older 2-terminal "v1.01" boards with a green back (#206606). This particular model of Henry is one with a plain green Hi-Lo rocker switch (i.e. no LED).
I'm just wondering if the PCB or switch is likely to be the issue given the strange symptoms, or something else entirely?! I know it's a really old model (2004?) but was in storage for a very long time so seen very little use and only spotted this issue when I started using it again recently.
Any help/guidance on where to start troubleshooting would be very much appreciated!
Adam
If you haven't got access to test equipment, it's hard to say what the issue really is.
However, a good guess would be a problem with the PCB.
According to here:
https://www.candorservices.co.uk/products/numatic-2-speed-control-pcb-for-henry-etc
The #206606 has been replaced by the compatible #206735, and is still available.
Other than that, my first vacuum cleaner didn't have any power control - it relied entirely on a sliding cap on the handle to open and bleed suction.
If you can't find a solution, you can always drill a thumb hole in the handle! ;)
Bound to be the PCB, I have had some weird faults with them at times, best to by pass it, the slow speed is of little use any way.
