high pressure/fast leaking Baxi Duo-Tec Combi HE
14 Aug 2007
London
hi,
You guys were very helpful when I was choosing this boiler a year ago. Fitted & commissioned, I've been very happy except...
the kitchen tap has never managed to keep up a flow of hot water without my turning it on really hard, and then often turning it off & on again after a couple of minutes. (The boiler is upstairs in the bathroom, dunno if that's relevant). the upstairs tap was okay.
so... I've waited until it's almost out of guarantee <sigh> to get around to do anything about it.
and now - the drip which I noticed recently from the overflow pipe outside has today increased to a trickle. Checking the pressure I see it's over 4. also the hot water upstairs is far from instant (as it was until recently). I've now turned it off. The drip/trickle continues.
Only thing that's changed recently is turning on the heating occasionally. But the kitchen hot water problem was always there & the upstairs tap has, I think been getting gradually worse.
Any ideas?
many thanks,
J.
Firstly check that your filling loop is turned off fully.
Next it could be that the expansion vessel has gone flat (See FAQ's on how to check this)
If these are ok the only other way you can keep getting the system re-pressurised without you touching anything, is a holed plate HE.
TRy a "tap reviver" on the kitchen tap.
