Hello...
I have 2 HIVE thermostats and 2 receivers (V3 models) as I have 2 heating circuits from one system boiler and a closed loop hot water tank. The HIVE system was installed 11 months ago, all working perfect until I go away for a few days and turn the water off on the APP (as I always do). When I returned I switched it back to schedule on the APP but it isn't heating the water.
What I found....
1. The receiver does switch on when told to do so (the green light comes on) by the APP but it doesn't activate the boiler. You can also manually turn it on by pressing the button on the receiver.
2. I can get the hot water to work by turning the heating on and pushing the hot water motorised valve to manual. I should also say the valve lever is stiff to move (not energised ?) so I believe that is good and there are no issues with it, but who knows.
3. I therefore thought it might be a loose connection so I have checked all the wiring and junction box and can't see any issues.
4. Last try was buying a new HIVE receiver but that gets me the same result.
Not sure what else to try.
Any help greatly appreciated while I wait for my busy plumber to attend.
What I found....
