Problem in kitchen which I hope is not a propblem. Wonder if you can help.
Had to disconnect our hob for one day. decorating.
Did nothing to the wiring at all.
Re-connected last night and the system tripped.
Diconnected once again, checked for break in cable - couldn't see any.
Reconnected, turned back on - no problem. System didn't trip and hob works.
As a double check multi-tested the neutral and earth and found some resistance. Is this normal - should the system have tripped again?
Tks
Moosehead
Tks
Moosehead
