Home lighting wiring confusion ???
Well thanks for all the feedback my friend - I'll pop round his later with my new found knowledge and see what I can do
Everything is connected to a 3 switch wall socket?
Wall socket?? What do you mean by a wall socket???
A wall socket has rectanglar holes and you plug things into it (eg a Hoover).
Or did you mean something else, a 3 gang light switch maybe?
If so, please clarify - cant begin to help unless you type in the correct words.
Kind of difficult to know the exact correct wordings unless you take a keen interest or deal in sparks - Evidently neither of which I do.
So its a 3 gang light switch?
All sorted now - It was a case of connecting the 2 remaining black wires together in a separate connection block then connecting 1 red into the loop and 1 into the neutral - and walaa - job done!
Cheers to everyone that responded and to rocky above for resizing my photo - this really is a top forum
It all seems so easy when you know how ;)
I wouldn't have thought you did need either of those to know the difference between a socket and a switch, but there you go...
A red being used for neutral??? :confused:
I was just thinking that...
stop right now and figure out which wire is the switch wire and swap the other one round so that there is a red and black in the terminal block ( switched black and red to light ) and a black in the neutral..
live to switch ---Switch --- Switched live ---|--- Switched live to other light--- Light --- Neutral back to rose
