HONEYWELL GAS VALVE
13 Nov 2010
Yorkshire
IS IT POSSIBLE TO GET A HONEYWELL V4600T 1011 GAS VALVE.
AND ARE THE DIDGETS 1011 OF ANY RELAVANCE.
thank you for any help
do's this valve exist anymore. because i have looked everywhere on the internet.
is there a alternative?.
kevin
Honeywell Service Replacement Valve is V4600C availiable ex stock less than £100 ;)
Hi Fellas
14 years later...but I'll give it a shot as I'm on my night shift ;)
My gas fitter has diagnosed my Rayburn 380g Honeywell V4600T 1011 gas valve as faulty .
As gas safe guys are busy, I am tasked with getting a replacement gas valve for him to fit.
After interneting this to death I have found the following.
A new replacement V4600T for £362
The 14 year old long shot comment (above) that the V4600C will replace the V4600T ...The V4600C costs anywhere from £100 to £150 ish
Is this the case ?
Is there anyone I can ask ?
I know it's an old boiler but I'm not going to get it replaced this side of Christmas and it getting cold....
Yours in Hope Chris
Thanks Ian
As far as I can see from the information online.
The V4600C is Softlite with Regulator
The V4600T is Slow opening with throttle valve.
I think I'll check about a bit more by speaking to someone at Rayburn and get some solid information first hand from them (as you suggested in the other thread)...but I'll probably go for the £365 direct replacement anyway ....unless I get a that solid information from Rayburn.
Regards Chris
(Copy and pasted from sources online)
The Suffix's are as follows for the V4600
A=Fast Opening With Regulator
B=Fast Opening Without Regulator
*C=Softlite Opening With Regulator*
D=Softlite Opening Without Regulator
E=Fast Opening With Throttle Valve
Models
V4600 serie: 220/240 V, 50 Hz.
V8600 serie: 24 V, 50 Hz.
Suffix E: fast opening and throttle valve
*Suffix T: slow opening and throttle valve*
Just adding this from BES gas parts site
"Honeywell Home V4600C1086 240 V compact gas valve to replace fast open or 'Softlite' 1/2" BSP inlet/outlet compact gas controls dating back to 1976."
