Long story short, our house is 7 years old, we moved in a few months ago. As per old house, we wanted a wireless programmable thermostat instead of one stuck on the wall.
It works fine in the sense hot water turns on/off as desired, heating comes on/off as desired.
Last few days though, we have had an issue where the boiler would fire on (thermostat saying it is off), a rad in the bathroom would get very hot (all others cold) and the hot water tank sounding like it is on/heating up. All this whilst the thermostat said the system was off.
After much head scratching I rang a plumber who very very kindly listened to my issue, was perplexed and said his guess was that the wireless thermostat was 'leaking' power through, meaning that it would turn the hot water off as switched, but was allowing enough power to leak through to allow the hot water to come on again when the temp dropped.
Now, this sounds very feasible. Hot water comes on for 30 mins early evening, we have showers then late evening it starts 'randomly' coming on for 5-10 mins at a time. He also guessed the rad getting hot in the bathroom is due to the system being set up so hot water on = someone wants a shower = rad in bathroom alone gets hot = warm shower, then warm room. Again, sounds feasible.
Now, I need to find a way to fix this. Would something as simple as a resistor (or such?) on the hot water switching side to reduce the voltage/thereby reducing the 'leakage' be enough to fix it? My friendly sparky fitted it a few weeks ago, so all work will be done by a professional, but I would like to ring him with some suggestions first.
Any suggestions? Cheers guys
edit: Thermostat:
http://www.heatmisershop.co.uk/ther...ss-programmable-thermostat-with-hw-output-p84
edit: Thermostat:
