Hi knowledgeable people. I am currently converting my attic to a bedroom with ensuite. I suddenly realised that the shower head and hot water tap will be above the cold water tank feeding the hot cistern.
Through a bit of reading I believe I need a negative head pump, my question then is where does this need siting. Can it sit next to the cistern or does it have to be above the shower so that when the shower or tap are opened there is some gravity flow to turn on the automatic pump?
Also can I use the twin ended shower pump to feed the tap as well (not used together) or do I have to use a separate pump(bearing in mind -ve pumps seem rather expensive)?
Many Thanks
Nigel
Many Thanks
Nigel
