Hot water
13 Feb 2009
Durham
Hi, my boiler works fine for the radiators, however it doesnt for hot water, if i run hot tap slowly the water comes out hot (only if the heating is on) but if i run it fast the water comes out cold.
Any ideas?????
It is a Baxi boiler, it has a dial which says tap/radiator and another which says tap. When it is on tap/radiator the heating works fine, but the water only comes out hot if you slowly turn the tap on, if you open the tap fully then the water runs cold, if the dial is on tap only the water runs cold all the time.
Hope this is enough information!!!!!!!
If not what more do you need?
The model?
I drive a Ford and my wife a Peugot. The Ford doesn't work. Now answer me that ;)
Could be a flow switch, diverter valve, plate heat exchanger, thermister, the colour orange, don't know 'till you tell us what you have I'm afraid...
We're only trying to help you know.
Model no : Combi80 Eco
Had to take front off as doesnt say
Hope this is more helpful
Read the manual
Just kidding, but it is fairly straight forward.
if you need the manual send me an email.
