if i only put a small load in the machine it washes it fine,but as soon as i put a normal size load in the machine when it comes to spin off it pumps all the water over the kitchen!.......any ideas?...all help gratefully recieved
More information would be helpful.
As Breezer says, check the stand pipe first.
If the water is coming from the machine rather than the stand pipe, check the door seal for holes, especially at the top.
Failing that, you'll have to watch it and see where it's coming from.
It's not draining fast enough.
Power off and take the sump hose off, there's a filter basket in there and it will be full of debris. Might even find your life savings there
