hotpoint aquarius wd420
27 Mar 2010
maybe somebody know where is the problem I'm starting the program it starts and after some minutes ON/OFF button and Reduce Creases button start to flash, nothing going on and after while its turning off.
machine is not working. so where can be the problem?
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty
thanks for quick response
i would be great to know what should i do :rolleyes:
Start by telling us what number light is flashing reduce creases mean nothing is it number 1234 on the left then look at error codes ignore on /off button.
so was flashing light 2
i checked the presure swich by these instructions
Unplug the appliance and take the top off.
Locate the pressure switch, circular device with wires on it and identifiable by the thin tube on the bottom of it.
Take the thin tube off, blow down the tube as hard and as long as you can to try and dislodge any debris. It won't take much effort to blow down the tube.
Give the pressure switch a couple of good taps with your screwdriver handle.
so the machine start spin a litle bit longer then before and starts dry.
but not washing.
now starts flashing first light. and there is the bad smell.
I'm plug in in washing machine in socket. and after few seconds it start work it means I'm not pushing ON/OFF button but its start flashing Light 1.
