Help!
I've stripped the machine, made copious notes and taken loads of photos. I've bought a new bearing/seal set and waiting for a new spider & shaft.
I've split the tub and removed the outer bearing but am having great difficulty removing inner seal and bearing. I've seen a spring between the inner seal and bearing-does that spring need to replaced or is it inside the new seal?
What's the trick for removing seal and inner bearing?
Cheers-Rob
Cheers-Rob
