Was working fine until door latch failed, spring had disconnected, new latch fitted and functions fine but now whatever programme you select the machine initially pumps then will not fill. When you open the door the third (rinse) LED is flashing. If you select a programme and hold the door open after about 30 seconds the 3rd LED then flashes. Any suggestions?
