Hotpoint WD420 wont spin (not brushes)
12 Feb 2009
Yorkshire
The pump was blocked last week. Took the pump off and removed a hair clip.
It had all been working fine, then today the machine will not go into a fast spin.
When you put the machine on spin only, the pump runs, the machine emptys, then the pump stops and the drum just turns slowly. If you leave it the pump kicks in after about 90 seconds. Then the same happens again.
The brushes are fine and I cant find any loose connections.
Any ideas please?
