Morming i have a hotpoint WD62, when put on a washing cycle ie: E, it will not complete the cycle, i have to move on the settings to spin and drain and rinse on the dial.
Does it stick several times on a programme? If the heater or temperature sensor fails it can stick during the wash but once onto the first rinse it should do the rest of the programme without sticking.
If your water pressure is very low it could be timing out before it has reached the required water level. Similarly, if there is a partial blockage in the internal or external plumbing it could be timing out before it has emptied properly. If these functions are working OK then it quite likely is a timer fault.
not having worked for HP for some years, so I may be wrong, but does the "timer" not sit and wait before it moves on? so in the case of fill / rinse fill, will it not sit there waiting untill the pressure switch says it is full? becuase thats what they used to do.
In my time with HP i actually saw very few timer faults, changed lots becuse something else caused them to go wrong / burn / damaged, but cant think of an actual timer causing a problem
Based on empirical observations rather than any knowledge of their circuit logic, these models with one piece timer/module units seem to detect a fault in the motor or other systems and shut themselves down. The later computer controlled machines can supply diagnostic information to the engineer but these are not that clever.
yeah played about with the machine lastnight, pressure wasn't great, so connected the cold from another source, and seemed to work fine i it was down to the water pressure
the drum bearing might be shot now though!!! are these easy to change, and where would i buy them from
There is normally a restricter in the cold water valve to prevent flooding if you have high water pressure. If your pressure is unusually low you can remove this. Take off the cold hose and pull the inlet filter out using pliers. You should now see a coloured plastic disc with a black rubber ring round it in the centre of the inlet orifice. Pull this out with the pliers and refit the filter and hose. For the bearing job, see: //www.diynot.com/forums/viewtopic.php?t=22543
I think i have seen bearing kits on Ebay but there are a few online shops such as www.ezee-fix.co.uk
