How much MOT hardcore do i need ?
27 Jul 2006
Hi there,
Can anyone confirm how much MOT hardcore i would need please for the following dimension on my driveway :
7m x 4.5m
I need a compacted/finished depth of 50mm
I already have a solid hardcore base and this layer is simply bring the overall level up sufficiently to then gravel straight on top
I've found a number of online calculators which have returned everything from 2.6 bulk bag to 4.5 which seems to be a pretty wide and wild range ! :eek:
Many thanks in advance !
Just over 3 tonnes
thanks for the quick reply denso ! (y)
do you use a particular online calculator or if not, can you educate me with your maths please ?
my head was telling me get 2 bags first, rake it around and if i still needed more, to then order that separately as its free delivery
7 x 4.5 x 0.05 = 1.575m³
roughly two tonnes in a m³, therefore 1.575 x 2 = 3.15 tonnes.
Remember a large bulk bag is short of a tonne, normally.
Bouy / Denso / Blup - cheers guys, much appreciated !
All coming in just over 3t (y)
I've used the same calculation for many years for hardcore and concrete, basically m³ x 2.
Rule of thumb for decorative chippings is that 1 tonne will cover 10m² at 50mm deep.
awesome, thanks again denso !
i meant to ask denso, what's your thought on the percentage compaction ?
will 100mm compact to 50mm or is that optimistic ?
If you had a bulk bag of MoT do you think if you stamped on it , it would reduce to half its depth? 10 -20% compaction at a gusstimate but your ground beneath may also compact
