How much sand,cement etc.?
7 Dec 2007
I need to mix 2.5 cubic metres concrete using a 3:2:1 mix
I plan to order 2 tonnes ballast(correction-gravel), 1.5 tonne sand( slightly excess) and 24 X 25kg bags Portland cement.
Does this sound approximately correct.
I dont mind if I over order the ballast and sand
why are you ordering sand seperatly, ballast has sand already in it
Thanks for the correction-I meant 19mm down gravel
A 1 tonne bag will be about 2/3 to 3/4 m3.
And 7 bags 25kg cement per tonne bag?
