Hi Guys,
Bought some wickes rebated door casings and hoping to install them this week. I believe I need to assemble them square before putting in place. Should I add some wood glue into the joins, or not bother?
I will then use diagonal braces to hold square, put it in the hole and use spacers until all plumb and square. My walls are a combination of brickwork and studs. Should I always screw through the door casing into the wall/stud and then simply put filler over the screws or is there another way?
Also how and where should I place the screws? I assume these need to hold the door casing very firm so that there is no movement later.
