how to dry out sodden wooden floorboards
Discussion in 'Wood / Woodwork / Carpentry' started by oldterry2, 5 Dec 2011.
  1. oldterry2
    16 Jul 2010
    34
    Thanks Received:
    Northumberland
    Country:
    Sorry if this is considered inappropriate, but I asked this question in the flooring forum but noone has come up with any ideas, so I hope you may be able to help more.
    The problem is how to dry wet floorboards which extend under other flooring.
    In more detail, I have a shower room, in which vinyl flooring has been laid on 6mm plywood (I think - this predates our getting the house) on top of the floorboards, which are suspended on joists about 15in above ground level. This vinyl and ply goes around the shower tray base surrounds. I've just had to get under the shower tray, and on removing the tray surrounds, it seems the seal between the base and the surrounds has failed some time ago, with the result that the bit of the floorboards in the gap is soaking with damp. I don't know how far it has spead under the ply, but it doesn't seem to have spread past the batten used to brace the surround. So:
    any advice on the best way of drying out these floorboards?
    If I can't dry them out is there any wood preservative I can use to soak into the damp boards to stop any rot starting?
    Any other suggestions?
    Note the shower is out of use until I can get the floorboards dry, put the base surrounds back and seal it properly this time.
    I don't want to have to remove the vinyl flooring and hardboard and then have them reinstalled if it isn't necessary.
  2. big-all
    12 Jul 2004
    15,892
    Thanks Received:
    1,096
    Surrey
    Country:
    the answer is you must remove them or seal and take the risk
    can you get under the floor to look or take a picture from maybe an adjoining room ?
    • Thanks Thanks x 1
  3. foxhole
    14 Mar 2006
    9,864
    Thanks Received:
    1,042
    Kent
    Country:
    If you can lift a board and get a fan heater under there you may be able to dry out the timber, depends how long it's been leaking though, may have damaged supporting timber [joists].
    • Thanks Thanks x 1
  4. handyman77
    8 Nov 2011
    859
    Thanks Received:
    43
    London
    Country:
    Wouldn't use a fan heater, try and dehumidify first u don't want it to dry to fast.
    • Thanks Thanks x 1
  5. oldterry2
    16 Jul 2010
    34
    Thanks Received:
    Northumberland
    Country:
    I was afraid that would be the answer.
    Not easily, but that is a sensible thing to try and do.
    I have borrowed a dehumidfier and put it in the shower room; and have a fan heater, set to cold, blowing over the damp bit that is showing.
    I need to have the shower room in operation over the Christmas period due to visitors coming. So it looks as if I will have to seal it back up over that period and then remove the vinyl etc in the new year to find out what the situation really is.
    Thanks for the help.
Loading...
Share This Page
