So I have a wardrobe and the left door is twisted on the side that opens. The bottom right of the door clips just fine but the top right is out by about 15mm. Any ideas how to make it straight again?
Many thanks imk
just an idea,next time you have a hot bath/shower take the door into the bathroom with you.then find something heavy to place on it to keep it flat.
it might work??
before going for gregers sensible suggestion
just check the front face is flat
if a corner is leaning back or forward compared to the rest off the frame one or more doors may be uneven back to front and up and down
we all make little errors as you know
but as you know our friends look after us as you have looked after me with several similar mistakes on several occasions
Many thanks imk
