As mentioned on some of my other posts, i'm planning on replacing my gravity fed cylinder with an unvented or thermal store (depending on whether i pay for a pro or diy myself)
I've got a bosch worcester greenstar 24ri boiler, 2 years old, sealed system, S plan (i think).
My current system is 22mm in the garage until it disapears under the floor, the cylinder connections are 15mm feed and return.
I've found one of the inspection hatches they cut in the floor. The cylinder feed is 22mm until about 1m from the cylinder down to 15mm, but the return looks to be 15mm all the way back to the garage.
I can't rip up my lounge floor yet, but will and I'm sure i'll be able to replace all with 22mm, but hypothetically, is 22mm feed to cylinder and 15m return ok?
I'm probably going to put in about a 180litre cylinder, which will serve 1 bath, 1 shower, 3 basins, 1 sink..
Cheers,
Cheers,
