How has the company you work for told you to carry out and secure isolations?
If you're alone in an empty house and electrocute yourself, can anyone hear you scream?
Rubber shoes are amongst my best friends.
This is a wind-up, right??
Well, what do you wear?
you knew you could have disconnected the lives at the CU. Why didn't you?
Because I couldn't be rsed.
I use the Wylex lockoff device. It doesn't fit all, but fits the vast majority of S and DP switches.
But not all.
Are you qualified?
Spark123 said:
The last time I really got a bad rattle was when a fluorescent fitting was replaced - isolated, secured, tested dead. Only when the neutrals were parted did 230v become apparent on them from a upstream fitting on a different fuse icon_cry.gif
Which tells us that there is no such thing as 'safe isolation', and the sooner people stop believing that there is the better.
As securespark works for a company, similar to myself we have set down procedures which we must work to - to ensure the circuit is effectively isolated.
It may be that if he can't secure the MCB or isolator that he must then take out the wires from the MCB so that if it is closed it won't energize the circuit being worked on.
I don't think the factory where I work would allow me to switch off the big switch every time a fluorescent fitting went
