Ideal classic nf 40 sealed system boiler with megaflow tank
i'm a DIYer
I have a ideal classic nf 40 sealed system boiler with a megaflow tank fitted upstairs. the problem I have is even though there is no demand from the timer clock for heating or hot water the pump fitted on top of the boiler is constanly running thats even if the main switch on the boiler is in the off position. If I turn on the main switch on the boiler the boiler will fire up even without the timer clock demanding heating or hot water. I have tried disconnecting main components separatley to see if that the problem i.e thermostat, air press switch over heat thermostat but as I'm not too sure I'm really stuck. i'd be very grateful if anyone could help with a little direction.
Have been in the house about six months and it hasn't done this before. Doing a bit of research could it be the pump thermostat over ride switch. The pump may still think there is hot water in the system so to safe guard boiler its moving it around unitl it gets cooler. The water in the heating system and hot water is cold though.
i'm a DIYer
